jcalderonMJMXC
593 Views, 4 Replies
Full Manual Nesting
Need full manual nesting that is as simple as click and drag. The auto nesting and the limited options to manually move parts is painfully annoying. I need best material utilization while at the same time having a linear pattern to cut, something that seems to be one or the other with fusion for the most part...yes on occasion it will auto-nest perfectly but its like throwing the dice and hoping for the best. Working for a manufacturing company this is a disaster.  Please fix this
LanceTSM
in reply to: jcalderonMJMXC
Are you referring to Fabrication CAMduct nesting or Fusion360?
For a more intuitive manual nesting with click-and-drag options, you might want to check out NestFab or Cutting Optimization Pro.
Manual nesting with click and drag would be a game-changer for precise material use and efficient cuts.
This is already available in CAMDuct.
