EmreYucel34
326 Views, 1 Reply
NC Codes for Fabrication CamDUCT
Greetings, I think we need to create an NC code in order to proceed to the manufacturing stage after making the design in Fabrication CamDuct, can you help me on how I can create an NC code? Thanks in advance
The NC code is generated for a specific machine. Is your machine in the supported list?
https://help.autodesk.com/view/FABRICATION/ENU/?guid=GUID-61CD687E-26A5-40BE-A2E6-E22DD0F6EA7C
If not, you will need a custom postprocessor (VPL) for your equipment.
Vladimir Michl, www.arkance-systems.cz  -  www.cadforum.cz
