anuj.shiwal
80 Views, 0 Replies
Anuj
I am working on creating a fabrication database for PVC through Fabrication CADmep and its final output should be work with this database in Revit. I have selected the service template as "Charlotte-PVC-Sch40_v2". Please find the snip below for reference.
After reloading this configuration to Revit, I could not draw PVC pipes with fittings. It shows the below error message.
Error: Fabrication fitting could not be made to fit.
The fabrication service does not have a part to fit the connection. Edit the service to add a part or remove the exclusion setting from an existing part.
Please Advise.
