- Mute
- Permalink
- Report
Compatibility issue with one of these Fabrication products and the others.
Which Products are not compatible with the following?
Advance Steel_ AutoCAD_ AutoCAD_ Map 3D_ AutoCAD MEP_ Fabrication CADmep Fabrication CAMduct Fabrication ESTmep_ Factory Design Utilities_ Navisworks_Revit_Advanced Steel.
Which has to be removed?
I am thinking AutoCAD MEP
- Mute
- Permalink
- Report
I'm not very clear on what you are asking.... If its which products from the below list can be integrated into each other and what doesnt? Then:
AutoCAD Advance Steel - (AutoCAD, AutoCAD, Map 3D, AutoCAD MEP, Fabrication CADmep, Factory Design Utilities) Can be imported into Navisworks & Revit_Advanced Steel.
AutoCAD - As per and Inc Advance Steel.
AutoCAD Map 3D - As per and Inc Advance Steel.
AutoCAD MEP - As per and Inc Advance Steel.
Fabrication CADmep - As per and Inc Advance Steel.
Fabrication CAMduct - CADMEP & ESTMEP only through MAJ Export.
Fabrication ESTmep - CADMEP & CAMDuct only through MAJ Export.
Factory Design Utilities - As per and Inc Advance Steel.
Navisworks - Can import most file types. CAMDuct and ESTMEP excluded.
Revit_Advanced Steel - Can import DWG, SAT, etc. File exports but functionality of Revit Advanced Steel would be lost.
