Hi Craig,
Thank you for your reply.
So basically I would like to create a design line based on some points and run the fill 3d command. There will also be need for editing nodes in order to get  the exact setup I want.
The problen with running commands with the editor.Command() method is that it does not recognize fabrication API commands until you press a button on the toolpallete.
