ZTR88
246 Views, 0 Replies
Terminal Setup For Fire Sprinklers
I've been trying to setup "Terminals" for different sprinkler head types on a FlameGaurd CPVC system. It seems I can only get the terminals to populate if the Sprinkler head used for the terminal is the same size as the drop pipe serving it.
For example a 3/4" MIP head with a 3/4" drop populates a 3/4"x1/2" head adapter with a 3/4" MIP head (Which is wrong)
The head is almost always a smaller size then the drop. For example I need a 3/4" drop with a 3/4"x1/2" head adapter to populate along with a 1/2" MIP head.
I have the terminals setup in the service with these button codes assigned for "at terminal" and "after terminal", but as I stated, I cannot get them to populate properly unless the drop pipe size matches the head size (which in reality is pretty much never).
Any help would be appreciated. Thanks,
Tags (1)
Labels (3)
