pendean
in reply to: RickySeymour3122
@RickySeymour3122 wrote:
Fresh plain Acad 24 opened.
Inserted two blocks via the palette and both tried to open Fabrication.
DWG attached.
Thanks for sharing: I opened your file in plain AutoCAD 2023 and 2024 (I do not have FAB installed) and inserted additional copies of your blocks. No FAB prompt kicked on or much of anything else.
Inserted a few of my own blocks, nothing.
Started a new file, copy/pasted your blocks into this file, nothing.
Used ADCENTER to drag/drop your blocks into yet another new DWG file in 2024.Nothing.
Created a custom TP from your DWG file, dragged/dropped each of the two blocks into yet another new DWG file. Nothing.
I'm going to guess your post needs to move to the FABCADMEP forum to see if fellow FCM users like you can see this issue and replicate it. I can help you move this post over there if you don't wan to start a new post here is the link to that forum https://forums.autodesk.com/t5/fabrication-cadmep-forum/bd-p/165
