03-13-2023
01:09 PM
- Mute
- Permalink
- Report
03-13-2023
01:09 PM
Go into your connector library. Edit the connector you are using for the slip-on portion of the flange. Edit the Breakpoints. If I recall correctly, you have to set the value of the "snap offset" column as follows:
(("Total Length of the Slip-On Flange" - "Setback Length") * -2)
It's been a while since I did this, but I think that will work for you.
