Mike_Arcari
in reply to: ouB4B8D
Hi There
nothing wrong with your description but i think my explanation may be confusing.
  1. create your part using the makepat command.
  2. add the item to a job.
  3. now open the part and in the developments tick the items you dont want cut out, and close the part
  4. now from you job contents screen ...right click your part and hit save as catalogue....you can select the previous part name from your makepat and this will save over your original part in the database.
  5. now when you add this to your job the not cut boxes should still be ticked everytime.
if this does not make sense i may have the time to create a small video showing what i mean when i get the time
best of luck
