Mike_Arcari
in reply to: ouB4B8D
Hi There
it seems that if you check the not cut box on the pattern development in the library and then add it in to a job the not cut box becomes unticked. Thgis is an issue with camduct.
This is not something i have discovered before but a way around this is to add the item to your job, open up the edit part screen and develop it, then tick the not cut box on the patterns you dont want and close.
now save this as a catalogue item into the part folders and it retains then not cut option for each part you selected.
not a perfect solution but it works.
Also if you right click an item and select options and then costing you can change the entire parts cut type from here. this may be of more use unless you only want some of the patterns within a part not to be cut. this method will cut all or none of the part.
hope you understand the explanation and it helps.
