ajay.js
765 Views, 4 Replies
HOW TO ACCESS CUSTOM FABRICATION DATABASE IN REVIT?
I HAVE CREATED FEW DATABASE USING CADMEP SOFTWARE IN THE PUBLIC DOCUMENTS->AUTODESK->FABRICATION. I TRIED TO LOAD THE CUSTOM DATABASE IN REVIT BUT THE CUSTOM DATABASE IS NOT SHOWING IN REVIT FABRICATION PART SETTINGS. CAN ANYONE HELP ME WITH SOLUTION?
PLEASE HELP...!!!!
MOatman
in reply to: ajay.js
You need to add the database you have created to the "Edit Configuration" program using the NEW button.
You need to use the "Edit Configuration" version that matches the Revit version.
The link below provides more information.
https://knowledge.autodesk.com/support/fabrication-products/learn-explore/caas/CloudHelp/cloudhelp/2...
or this link:
Justin_Doughty
pinaki.rajak
Configure the CUSTOM database in Fabrication CADmep First. Once it is loaded completely. Open Revit Fabrication of a similar version. The Custom database will show automatically.
Only one condition: the version should be the same for Fabrication CADmep and Revit.
nhemmDLYAY
You need to have the fabrication database pathed in the same year of Fabrication CAD before you can load it into the same year of revit. it is important that the year of revit and fabrication CAD match or you wont be able to load it in revit.
once you have the database pathed in CAD, navigate back to the fabrication settings in Revit and the option should be there for you to add the database.
