11-21-2022
11:28 PM
- Mute
- Permalink
- Report
11-21-2022
11:28 PM
There are several possible things that may affect this.
First - Try your machine settings under Installed Machines - Setup - NC Settings- Part Ordering
Setting Along Rail Axis or Along Beam Axis may change this. Also under Method there is Shortest, Left to Right, Top to Bottom etc.
Otherwise you can move the Start Points and Set the Cut Order as desired either per Part in Profiler
or Per Nest in Manual Nest.
