11-21-2022
11:02 AM
- Mute
- Permalink
- Report
11-21-2022
11:02 AM
In CAMduct 2019, when I preview the NC for some gored elbows, I notice that the travel movement between cutting the seams of the gores takes the longer path from top to bottom(see attachment). Is there a way to change the travel path to take the shorter path between the seams of the gores. My end goal is to reduce total movement for each sheet burned to prevent unnecessary wear on the plasma cutter and to shorten cutting time.
Thank you,
