Mike_Arcari
in reply to: dimitry.shan
If you select all the parts you want to export in viewer and choose export dxf file or export dxf with layers this should export the parts with overlaying lines also
by the looks of your screen shot you have exported the dxf parts from a nest which will not export the other lines
also note that dxf file export will only do a qty of 1 so if you have a qty of more than 1 on any of the parts then you need to duplicate these manually
screenshot below of how I export them
hope this helps
