davidronson
in reply to: amedinaL65RV
You should be good. You might want to make sure you copied all the necessary folders. Configurations can be deployed in several different ways and if you dont understand the deployment then its highly probable you could be missing some key folders with .ini and .map files.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
