- Mute
- Permalink
- Report
very limited fitting library: Fabrication CAD MEP 2022 / 2023
Downloaded the trial version of the Fabrication CAD MEP 2022. Most for the pipe fittings are not there, very limited fitting library, for example 1X1X3/4 Tee is not there. Do I need to do download any content. Please advise.
***THE POST TITLE HAS BEEN EDITED FOR CLARITY***
- Mute
- Permalink
- Report
You shouldn't be able to use the trial for 2022, should be the 2023 version.
Did you click everything when you were installing it for options?
Mike Davis
- Mute
- Permalink
- Report
yes, I have installed the Fabrication CAD MEP 2023 trial version and also check everything while installing.
There is a library and but it has very limited pipe fittings. I was expecting to see all the fittings for steel and copper but vey limited. Is there any library content that I can download to get the fittings?
Thanks.
- Mute
- Permalink
- Report
Autodesk doesn't really provide any content anymore.
They used to provide a decent "starter" database with some real world items.
- Mute
- Permalink
- Report
Autodesk is dropping Fabrication development and only doing bug fixes in their new releases. One of the casualties is content. There are third-party content providers out there, of which I would recommend Virtual Building Supply (https://itembuilders.com/) who's proprietor is Scott Hendrix, a long-time Fabrication expert. They provide very solid content that is Revit-compatible.
