05-17-2022
12:11 PM
- Mute
- Permalink
- Report
05-17-2022
12:11 PM
Fabrication Parts designed to use in Field Layout Now reporting multiple points
Has anyone else encountered placing fabrication parts designed to be used in field layout, ie Trimble layout units. Now reporting multiple points overlaid on top each other. The points all have the same northing and easting coordinates. This happens on versions 2020, 2021, and 2022.
Jason Landry
SM BIM-VDC Specialist
Bernhard
Bernhard
07-03-2023
07:30 AM
- Mute
- Permalink
- Report
07-03-2023
07:30 AM
What CID pattern are you using to generate the points? Certain patterns allow for multiple points within the same itm.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
