edvance0108
585 Views, 2 Replies
Fabrication CADmep 2023 Connector Libraries Broken
The 2023 release appears to have broken Connector Libraries, or at least how they should be viewed. Accessing by the Fittings tab of the Database menu shows all Libraries empty (rectangular, round, oval). Existing pipework (round) Connectors are only accessible from the Options tab of the Item Takeoff dialog, however navigating away from this initial view to another Library by the drop down menu yields same result of all libraries empty as it was in the first method described.
I know its a new release and bugs should be expected, just wondering if I'm a stand alone or if anyone else is having this problem too.
Update: Issue resolved in 2023.0.1 hotfix
jonathanMHGJM
in reply to: edvance0108
I'm having this issue as well.
In the Database editing window under Fittings>Connectors changing the toggle from Rectangular to Round or to Oval does nothing. I have no access to round or oval connectors.
Guess I need to go back to 2021 for a fully functioning suite of fabrication software as camduct 2022 is too buggy to be of use to us.
edvance0108
in reply to: jonathanMHGJM
This issue appears to have been resolved by the expansive 2023.0.1 hotfix.
https://knowledge.autodesk.com/support/fabrication-products/learn-explore/caas/CloudHelp/cloudhelp/E...
