LRAndrews
330 Views, 2 Replies
Print to PDF Issues with 2022
I am having a rather unusual issue with my print commands in Fabrication CADmep 2022.  I always print to a PDF from the spool layouts using the Bluebeam PDF printer (screenshot of my settings is attached).  For some reason with the 2022 version it acts like it's trying to open the printed job in Fabrication CADmep.  When I browse to the folder where I told the file to print to, the PDF is there, and I can manually open it in Revu without issue.  But always before (in the 2019 - 2021 versions) when I click "OK" to print, the PDF automatically opened in Revu as soon as the print job was complete.  Now, in the 2022 version of Fabrication, I get the Fabrication CADmep start screen when the print job is finished, as though it's trying to open a new session of Fabrication, and I can't cancel out of it without canceling the print job, which just makes no sense at all.  When I select the database I want to use, the PDF opens in Revu as I expect it to, but the additional step is VERY strange.  Is there a setting I have unwittingly changed that is causing this?
It is also taking MUCH longer (minutes instead of seconds) to complete the print jobs, which I suspect is a side-effect of whatever setting is goofed up and is causing the error with how the printed sheet is opened upon completion.
