Daffy58
328 Views, 2 Replies
CAMduct
We have just updated to 2022. Now when we try to add a custom or dxf part to the job the gages of metal are not there. This has not been a problem in previous versions.2021-04-28_13-34-45.png
matthewweake
in reply to: Daffy58
This is a repeatable problem and I have reported it to Autodesk. They tell me it is already known and being worked on.
The suggested workaround is:
1. take off any other item from the Items Folders.
2. select both Opus part and Item > right-click > Properties.
3. set the material/gauge as required, here the list id properly filled up.
Matthew Weake
matthew.w@cadpro.co.nz
+64 9 302 4028
Daffy58
in reply to: matthewweake
We are just using the previous edition 2021 for now until this gets fixed.
