Mike_Arcari
in reply to: mattpick10
hi Matt
the standard fabrication database does not seem to have the metric and imperial content on version 2022 like previous versions on the fabrication software install.
you should be able to get this content by browsing to an older fabrication version(2021) and copy it in to the 2022 version folder.
The fab database can be found in c:\users\public\public documents\autodesk\fabrication...
there you should see the various standard database files which you can simply copy and paste in to the fabrication 2022 folder
Hope that helps
Mike
