297 Views, 0 Replies
Customizing the ESTmep UI
We have created a custom add-in for the Fabrication ESTmep product using the Fabrication API, and so far, everything is working very well with that. However, right now, we have a need to add a right-click / context menu to ESTmep so that we can get what the user has selected from the table or graphically from the viewer and pass that selection on to the command or add-in we have created. Would anyone on the forum happen to know if customizing this UI is possible in the same way you can inside of AutoCAD for example?
Also, the other question I have is about the Fabrication API, is there anyway to know for the current job and its items what the user has selected or filtered inside of ESTmep?
Labels (2)
