grahamP6L9M
in reply to: MOatman
Hi
Electrical Conduit is set up as a Service Type (#81) and I've added that into the Lighting & Power and Fire Alarm services in the Services Database.
The parts are happy as far as that is concerned, and appear on the correct layers etc.  But I can't work out how to be able to stretch one of the grips and have the new conduit tube I've set up extend out from the part.  Grabbing any of the grips just stretches the actual part in a singular direction.
I was advised on a different forum to use CID 1110 instead of the one I've used, but although this helps with the stretching of a grip a bit, it isn't flexible enough to accomodate all the various Besa box types.
I've attached the ITM's I've set up in case anyone fancies having a play.
Cheers
Graham
