camduct1
in reply to: matthewweake
We decided to start from scratch with the configuration as there were problems with the very old version we had.
We have a new database which we have configured with new materials & tool settings for our plasma cutter.
We can provide you with any of the MAP files from the new database.
I don’t recall making a decision to choose between imperial or metric during installation.
Our issue is the distance between the rip & the nest being too small & is not affected by the changing the default margin as suggested.
On opening a legacy nest we have a bounding box see nest1.png, this prevents the parts be nested to close together.
We seem to have lost this bounding box with the new configuration, we believe that this will also solve the rip cut problem.
I have also sent database config snap shots of metric config & default margin.
Hope you can help.
