jedQB94J
266 Views, 1 Reply
newbe in CAMduct
I'm family with Inventor, and some others CAD programs, but if I want to place some circles, and I want them also in a pattern, how should I do this? and how can I define diameter on the circle?
see video:-) https://autode.sk/2KAUG7z
Jacob
matthewweake
in reply to: jedQB94J
You are in the right place and doing the right things. Keep an eye on the message in the lower left-hand corner. The circle size is Radius but you can switch to Diameter.
It is like using a CAD product from the 90's. If you have AutoCAD or something else you are familiar with drawing in 2D, use that an import into Opus.
Note that you are not going to be making parametric Items like you make parmateric Parts in Inventor. What you draw in Opus is non parametric 2D.
Matthew Weake
matthew.w@cadpro.co.nz
+64 9 302 4028
