in reply to: mroble
@mroble wrote:
@Anonymous
While this does, indeed work.... (my mind is blown right now)
there's an additional step needed. Say you have an existing pipe with a valve on it. You want to demo everything from the valve and beyond. Prior to remain.
While the demoed pipe is pinned, you DO have to manually go unpin, and then delete the gasket and bolt set. Otherwise, when you go to add a new flange, gasket and bolt set to the existing valve, it remembers that something is connected to it and will not connect.
But thank you!!! This works like a champ.
@mroble So glad I could help! Sorry it was 1.5 years late haha I didn't happen to have those fittings in my run when I discovered this so thank you for trying this solution out and adding that part in there!  I did notice that sometimes it still may break in one spot despite being pinned. I found that sending the parts on either side of the break back to "None" in  phase demolished, re-connecting them, and repeating the pinning/unpinning process again can repair the break.
