Hi Matthew
My next step would be to check the setup for your Post Processor.
1. Un-tick the 'Auto Marking Settings' and see if you can post.
2. Assuming you can post without marking, go into Setup>Installed Machines, select your machine, select Tools... , your Marking tool and then Setup. Make sure these settings look right to you.
You could try contacting your Autodesk Partner or Autodesk Support directly.
I would normally do a remote session to resolve this sort of problem and charge accordingly.
I'm about to break for the Christmas holidays returning on 13th Jan.
Matthew Weake
matthew.w@cadpro.co.nz
+64 9 302 4028
