The simple answer is no, you can't do that.
The Fab Items are their own object type with little information actually in the brep of the 3d model. If you explode the objects you end up with faces that are of little use.
If you know the data that the tube cutter actually needs, you maybe able to extract that from the Item.
Good luck!
Matthew Weake
matthew.w@cadpro.co.nz
+64 9 302 4028
