09-11-2020
05:47 PM
- Mute
- Permalink
- Report
09-11-2020
05:47 PM
camduct Insulation pattern seam adjustment
Hello all, looking for some guidance on using camduct to generate insulation patterns. No problem getting it to generate rectangular patterns, but seam adjustments under Fittings>Insulation>Insulation developments for inside seam allowances generates incorrect pattern developments. It also applies length adjustments to both wrappers and cheeks even if only one of those options is selected. I am having issues with radius elbow patterns when the program reads from the insulation development database instead of the pattern options database. Any help would be appreciated. Male adjustment on the cheek is only being applied to one end of the elbow. C1 is correct, C2 is incorrect, so one end of the elbow is a different size than the other.
