avis_ambalathil
397 Views, 1 Reply
Connector based on double wall skin
Is there any option to show the connector based on double wall outside skin. At present when we give double wall outside skin, the connector end line (eg GRC Swage Male) is not visible. It is under the double wall. The connector is based on the inside skin only.
Doublewall is intended for inside lining only. What are you trying to achieve? Curiosity more than anything, as i see you're using pipework with a grooved coupling.
