MTBLetsos
748 Views, 1 Reply
Insulation Transparency when opened in Naviworks Manage
Can you set the insulation layer to be a level of transparency and have it keep those settings without having to make the same adjustment in Navisworks?
nathan.chapman
in reply to: MTBLetsos
I don't know a way out of CADmep besides using search sets in Navisworks but if you use fab parts in Revit you can just assign a transparent material to insulation and that will translate into Navisworks.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
