matthewweake
in reply to: fong.mingli
This looks like an old post with no responses.
When you install CAMduct you get the 'Autodesk Fabrication Database Migration' tool that you can find from the Windows Start menu. I have had varied success using it. Makes a good starting point to clean up your database.
The version of Revit and CAMduct/ESTmep/CADmep installed need to be the same year. I don't think the version of the database matters although I would always migrate so they are all nicely aligned.
Matthew Weake
matthew.w@cadpro.co.nz
+64 9 302 4028
