- Mute
- Permalink
- Report
Camduct Versions and Compatibility with Revit Software
Would like to know the following:
(1) how to export the material settings and connector settings from PM2000 (old camduct) to a current Camduct Versions.
(2) Is Fabrication Library V7.06 incompatible with Revit 2018? and only compatible with Fabrication Library V2.1. Am i able to create a standardized library based on V2.1 Fabrication Library for all Camduct and subsequent Revit versions?
- Mute
- Permalink
- Report
This looks like an old post with no responses.
When you install CAMduct you get the 'Autodesk Fabrication Database Migration' tool that you can find from the Windows Start menu. I have had varied success using it. Makes a good starting point to clean up your database.
The version of Revit and CAMduct/ESTmep/CADmep installed need to be the same year. I don't think the version of the database matters although I would always migrate so they are all nicely aligned.
matthew.w@cadpro.co.nz
+64 9 302 4028
