374 Views, 2 Replies
06-12-2020
10:17 AM
- Mute
- Permalink
- Report
06-12-2020
10:17 AM
Designline ductwork endcaps
When putting in a cap using designline, it will use the wrong size to put in the endcap. We are using two options for our endcaps, anything 10" and below should be a slip and drive, anything above, should be a TDF.
If I run a 8"x14" line it will put in a slip and drive cap (which is wrong). However, if I run a 14"x8" line it will use a TDF.
Obviously designline is using the first size to define what type of cap to use. Is there anyway to correct this issue so anytime a 12" length or higher is used for either dimension, it will apply the correct TDF cap.
