With the help of Autodesk I was able to figure out the problem. There is a known issue with straights, and developed lengths. From Autodesk support -
When dynamic holes are set to not develop, this issue can pop up. Our options are:
  • Develop the dynamic holes:
    • Under Database>Fittings>Patter Options>Holes> Dynamic branches section, check on "Draw Holes" and "Develop Holes"
    • Once the holes are set to develop, the straight in the connector will not be added incorrectly anymore
  • Export as a TXT and then import (This will need to be done in CAMduct)
    • If Dynamic holes cannot/should not be developed, the workaround is to export as a TXT and bring the items back in
    • Select all items in the job
    • Run the EXPORTJOB command in CAMduct (Use CTRL+SHIFT+C to pull up command line)
    • Name the file and save as a TXT
    • Delete all items in the file
    • File>Import>CAD/JCM Items
    • Select the TXT file that was created, and select Open
    • Items should import again, and now should show correct developments
I'm going to be doing some testing in the next couple of days, and will report back. I appreciate the time everyone took to help troubleshoot this!
