06-03-2020
10:30 AM
- Mute
- Permalink
- Report
06-03-2020
10:30 AM
Hello @dglus ,
Thank you for sharing that service! I was able to import it and take a look. I can see the connectors locked now, and placing two pipes using the attacher will place the coupling between them. And Design Line seems to do this properly as well. Have you been able to place a couple of these and see the proper behavior?
If you consider your question answered with any of the posts above, feel free to use the 'accept solution' button to mark it as an answer. Threads marked with solutions will show up higher in search results and will help people searching when they have the same type of issue.
