craigjonnson
in reply to: we.revitt
Default length settings are stored in the specifications.
Go into your database.
  1. Select fittings
  2. Specifications
  3. Select your duct specification if setup.
  4. Change the standard straight value. This is normally 100mm longer than your required length to allow for connector folds. You will have to play around with this to suit your settings.
