05-05-2020
06:01 AM
- Mute
- Permalink
- Report
05-05-2020
06:01 AM
Fabrication ITM OD and ID dimensions not matching the correct dimension
I am currently creating manufacture specific OD and ID for the fabrication parts and when I assign the OD and ID for a size, it is auto sizing to the next size up. For example if I select a 2" piece of pipe, it is placing the the 3" OD and ID specifications to it. I'm not sure if this is happening because the ID is actually larger than 2" even though that what the manufacture spec says, so it auto sizing to the next size up. Is there a quickfix for this or am I just missing something?
05-07-2020
04:17 PM
- Mute
- Permalink
- Report
05-07-2020
04:17 PM
There are varying methods to setting up pipe diameters within CADMep. The ideal way is to set these up in the materials section.
- Select Materials
- Drop down to a pipe material
- Double Click a pipe material
- Check the correct dia is associated with your sizes.
