ebeaumont
307 Views, 2 Replies
Main duct on riser wrong fittings with design line
When using designline I drew the riser first and then when I try to add a main from the riser the wrong fittings are mapped. I checked my button mapping but also when I change to other sizes the correct tap is shown
mariah.ferranti
in reply to: ebeaumont
Hello @ebeaumont
Can you provide more details on what is happening? It is hard to tell from the screen shots.
  • Is the same run able to be created manually, without design line, without seeing any errors? (If an error pops up when manually placing the items, we can see why Design Line is not entering them, and make adjustments).
  • If you take a look at The View>Troubleshooting in Design line, does it state that any items have failed to fill, and show any details?
  • What size is the riser, and what size is the main that fills correctly, and which size is filling incorrectly?
mariah.ferranti
Hello @ebeaumont ,
I wanted to check in and see if you are able to provide more details on what is happening, or if you have already figured it out. If so, are you able to share what the solution was, for anyone else who happens to have the same issue?
