mattpick10
554 Views, 3 Replies
Revit parts
Is it possible to create new parts for the revit fabrication. I want to creat a new duc set that does not have to be the set length set within the fabrication part for example a 600mm x 600mm to 400mm x 400mm would have to be approx 500mm long however due to site conditions I want to be able to make this any length I require
thanks
in reply to: mattpick10
Yes, you can. But you can't do it from Revit. Need to do it from CADmep, ESTmep or CAMduct.
mattpick10
Can you recommend any tutorials that can help me
MOatman
