Mike_Arcari
in reply to: njtingirl
Hi There
Looks like you need to setup your button codes for your parts on your service templates.
There is a section in the Fabrication software help file explaining the basics of how to do this.
also Autodesk fabrication YouTube channel has good tutorial on button codes and mapping that will help you.
Hope that helps you enough and good luck!
