This forum is for CadMEP, not AutoCAD MEP. They are 2 distinct applications. You could try posting there, but what you want isn't possible.
The only solution is to trace over your exported file with AutoCAD MEP objects.
If you want non-CadMEP users to view CadMEP content, they need to install the free Object Enabler.
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
