So, the part cut is larger than the part you programmed?
You may have too small a kerf value or the machine needs to be recalibrated.
Is the size equally off on both directions or different?  If it's different, than the machine needs to be recalibrated. One of the setup screens allows you to make adjustments for how for the machine moves given a configured input.
