252 Views, 0 Replies
10-31-2019
02:55 AM
- Mute
- Permalink
- Report
10-31-2019
02:55 AM
camduct Dimension issue
I have some issues using fabrication CAMduct :
-When adding the DIN dimension H in reports& labels it gives no value which is not logic( especially in Taper Pattern).
-when adding the DIN dimension I in reports& labels it gives no logic values.
that is because I want to add the Taper direction in the report & Label as a text value (Flat Right, Flat Left, or Center)
-when adding the dimension(G) in reports& labels it appears as zero value which is not logic.
that is because I want to add the dimension "offset width" in the radius offset pattern to the report & Label form as a number value.
So Please help in this issues
Thanks in advance
