369 Views, 1 Reply
notches - camduct
i would like to add a marker to the spot 0/15 seam connector so the factory doesnt have to mark every one they need to fold
can someone help with this?
Mike_Arcari
Hi Danny
Depends if it is rectangular or circular item and if it has connectors
Notches and settings are setup in database under fittings tab, you can find these either in pattern switches/developments or pattern options / notches
these settings allow you to notch out or v notch the ends making folding easy without the need to measure
circular and rectangular work differently so you will need to experiment
If you can tell me what part you are trying to achieve this on I may be able to give you some specific instruction or point you in the right direction
I'm not an expert but happy to help you
