540 Views, 1 Reply
Can't Specify Part Material of Parts from Fabrication Database in Revit
I'm currently using my company's database and have converted it from CADmep to Revit and most parts work okay however when I am trying to draw access panels and some other parts it won't let me draw it without specifying the part material, however when I go to do this it is greyed out (see attached).
MOatman
You have to fix the material from the database editor within Fabrication CADMEP (AutoCAD).  Then after making the changes, reload the configuration in Revit.
