Mike_Arcari
in reply to: kmilesZXEY4
you can change these settings by doing the following -
go to file menu and select print layout/labels
select part labels at the top left
right click on the graphical pattern view box and select properties
select properties again on take-off settings tab
select take-off style
from here you can change the text size and also other options relating to how it appears on the label
