engmostafa2008
435 Views, 1 Reply
export fabrication cadmep to autcad
now i draw duct line in fabrication cadmep then i want to approve that from the consultant but he have only auto cad not fabrication cad mep > how to do that?
jpnoronha
in reply to: engmostafa2008
Hi
You have to possibilities. The easiest, make the CADmep save the information in AutoCAD with "Save Graphic with Drawing" (in Edit Main Database>Takeoff>CAD Settings>General) , Have the consultant install the CADmep object enabler (allows AutoCAD to read the CADmep data https://knowledge.autodesk.com/support/fabrication-products/downloads/caas/downloads/content/autodes...)
Check this thread.
https://forums.autodesk.com/t5/fabrication-cadmep-forum/how-to-make-fabrication-cadmep-viewable-by-o...
Hope it helps
Regards
