- Mute
- Permalink
- Report
I am new to fabrication. After setting up all of the connectors the way that I want them, I find that (upon using them in jobs) the jobs add duplicate connectors to the list of connectors similar to the following:
TDC
TDC {job}
TDC {job}
TDC {job}
Is there a way to prevent this duplication of the connectors in the database?
- Mute
- Permalink
- Report
Hello @bdean123456 ,
I don't think I've seen this before, are you able to post some additional info so we can narrow down what's happening:
- Does this happen with every job you use them in, or does it only seem to be a few specific ones?
- Is this happening to every connector used?
- Are you able to share a screenshot of this list of items with the job name appended?
- Does it seem to happen to every service, including the default Autodesk services, or is it one specific one?
Thank you in advance for the extra info!
- Mute
- Permalink
- Report
I wanted to check to see if you would be able to post that extra info to narrow this down, or if you had questions or concerns about the requested information. Don't hesitate to reply back if you need help!
- Mute
- Permalink
- Report
Our solution was just to open every job as a user without rights to modify the database. It is kind of a pain, but it is the only way that we could figure it out. To modify anything in the database, we use a different user and do not open a job, or use CAD, or the database editor.
Please let me know if you have further suggestions.
Ben
##- Please type your reply above this line –##
- Mute
- Permalink
- Report
I was able to talk to a couple colleagues about this, and we were able to come up with two scenarios that could cause this behavior:
- If the jobs you are opening up where created in a different configuration, they are adding their items to your database. Make sure jobs are created and used in the same configuration to prevent this.
- If the connectors were created in the configuration, and added to jobs, then deleted from the configuration, each job will start adding them back when opened up.
- You can right click any of the connections, and select 'Make permanent' to add them back to the database.
Some info regarding these scenarios and purging out the added items form the database can be found here: Purge Database | Fabrication Products 2017 | Autodesk Knowledge Network
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Are you able to record a screencast ( How to use Autodesk Screencast to document a support issue | Revit Products | Autodesk Knowledge Net... ) of creating a new job, adding fittings that exist in the database, saving/closing the job, and reopening it to see the connectors with {new.job.name} added unexpectedly to the list of connectors in the database?
- Mute
- Permalink
- Report
Here is the link to the screencast:
https://autode.sk/2FLxSME
- Mute
- Permalink
- Report
That is odd, let me try and reproduce on our end using these same steps, and see if I get the same odd behavior, or if things work differently on our end. That should start to narrow things down. I'll keep you updated with what we can find.
- Mute
- Permalink
- Report
Thank you for recording that screencast! After reviewing, and following the same steps you are taking, I'm still not able to reproduce this. Are you able to share the job created, saved in ESJ format? You should be able to choose ESJ when using file>Save and this will retain more information than a normal MAJ.
You can upload that here to the forum, or you can upload it to the link I will PM you if you would like to keep the file private.
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
I'm not seeing an attachment. If the post was sent as a reply email, the attachment may have been removed. You can upload the file directly int he forum, or you can upload it here: Upload a File
- Mute
- Permalink
- Report
Sorry, the file must have been removed... I have now posted it to the link you provided.
- Mute
- Permalink
- Report
No worries, it happens. I see the ESJ file in there now! I'll take a look and see what we can find, and if I get the same behavior now that we are working with the same items.
- Mute
- Permalink
- Report
I was able to finish reviewing the file with a colleague, and I think we may have found some things that can help. It looks like a few of your specifications are having issues due to missing items:
There could be something in the jobs that is bringing in this info to the specifications. Can you check through the specifications, fix them up so no red error text is showing, and see if the issue is resolved?
- Mute
- Permalink
- Report
Ben
- Mute
- Permalink
- Report
That may be part of the problem. Do other databases show the same issue, for example if you use the default imperial database, does it add a bunch of connectors as well after saving and re-opening a drawing?
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
For the user profiles, do you have them set up to duplicate the database? It could be that the database has been duplicated for each profile, and is attempting to save the connectors into the different user profile database.
Additionally, are you able to provide a new ESJ for us to look at, where these services have been fixed up so we can check for other areas that look problematic?
(As a side note, please disregard any notification about an accepted solution, I may have mis-clicked, this is still being looked into)
- Mute
- Permalink
- Report
