busterbw
885 Views, 8 Replies
lOCK-UP
Like I'm in Jail; When tyring to rotate a fitting, stretch a pipe, measure, etc. the cursor has like a magnet and grabs to anything it passes over and locks up for sometimes several minutes. Very frustrating and time wasted. It doesn't seem near as bad with snap turned off, but you lose the ability to select objects to work within the drawing. This problem seems to get worse with each newer version of autocad and CADmep. I just installed 2020 and does the same
